Figure from the 2011 Canada Convention
Traceroute is the counter cyber-terrorism specialist on the team. He is probably the equivalent of Data Frame I'm guessing. An interesting mix of parts were used for him considering he would probably be inside most of the time. Either way, the figure came out good with paint and dye applications. The head is a bit of a different color than the body though. Hard to match so many different plastics and paints.
The head is another Slayer Design one I believe. It seems they used it on most if not all of the figures this round. The flesh color paint could have been a hair thicker to hide the mold color but you have to get real close to even see it. Everything else on it is clean except where some red rubbed off on the bottom of the leg where it's white.
The arms are a little loose on it. This is the problem with the figures from time to time since they tear them apart and reconstruct them. Honestly though, it's a minor issue and is easily solved with proper posing with a weapon. He comes with a rifle and a side arm.
