I wasn't sure if this really should go in this area, but I thought I'd take a chance and share it here with everyone. If it needs to be moved, I understand.
I just recieved my Flying Styro A-10 kit in the mail. I took a few pictures of it to share with everyone. Below are pictures of it next to bbi's F-18. The A-10 is a doable aircraft in 1/18 scale as far as size is concerned. Flying Styro's website says that the kit is 1/17 scale but is really more 1/18 scale. The measurements are off by a gnat's hair. As you will be able to see in the pictures below, the foam texture show a little bit in places but not enough to really detract from what this kit can be.
Below is a picture of one of the engine housings with a 1/18 scale pilot figure:
Here are pictures of the Aces II Ejection Seat and pilot figure from my F-16 (the A-10 uses the same ejection seat). The other pictures are of the Ejection Seat in the cockpit tub that comes with the kit.
Overall the kit has a lot of potential to make a respectable 1/18 scale A-10 representation. There will definitely have to be more detail done in the engine area, cockpit area, and possibly landing gear area depending on what you are looking for. The engines will need a trubine fan in the front and an exhaust nozzle for the back. The cockpit will need a joystick and throttle quadrant. The landing gear come in a build up or down fashion. There is a kit you can buy to upgrade them to retractable if you are building it to fly.
There is also ordinance that comes with the kit for you to build and load it out with. All the plastic pieces like the ordinance are made from an almost paper thin plastic. All this is of course for keeping the weight down for those building it to fly.
I could see Pickel using this kit in two ways:
1. Creating upgrade kits in the areas I mentinoned above.
2. Using this kit as a templated to create a 1/18 scale A-10 in plastic/resin.
I don't know when I'll get to start building this kit, but I'll post pictures when I do. I plan on using this A-10 as a filler in my collection until someone hopefully gets the message and produces one in a 1/18 scale plastic form. I'm not giving up hope for that to happen one day.
