I have been trying and failing to figure out to paint a good multicam pattern. Has any one else had any luck with it? Care to share any secrets?
I find it hard to believe they need camo below the waterline.. and that camo is going to work on the open water??? Should be dark blue or black
Maybe if it was hiding on shore I suppose.. but still..
Do I need to mention the arah cartoon with shipwreck drivin a boat in the middle of the desert![]()
They are in the jungle!!! Geeze.....Some people.
Pfft, better than the mermaid episode.
Like anyone was buying that Shipwreck was straight.
Looks more like the tablecloth jungle![]()
Sometimes with small-scale figures, just the suggestion of detail is usually enough. Look at the camo paint jobs on the FOV Rangers for example. It's not accurate or true-to-scale but it looks "right".
In an urban environment I wondered how good multi cam works. I mean there are a lot of straight lines, box and rectangular shapes and blocks of solid colors. In jungles and forests I can see the need obviously.
