So when I first saw that the Jungle Viper was packing a Finnish anti-tank rifle I commended Hasbro for such a novel accessory. Sure, it's completely unsuited to the Jungle-Viper's MOS, but I was sure I could find a use for it SOMEWHERE.
To date, the only figure that really works with it is Night Adder.I can get him to prop it up on things and look fairly convincing. No prone poses, but what can you do?
Anyhoo, I had always intended to paint it, but just never worked up the desire. Well, it finally happened and i decided to work in a couple of mods.
Added a hand guard like on the real thing. grips are completely different,so I had to make it work. Also drilled another hole in the skies so it can be positioned with the spiked bipod legs in the ground. Also put in a new tube beneath the barrel. Trimming the excess plastic wasn't good enough.
Also put a charging handle on it.
Not sure yet if I'll add a muzzle break cover or not. Seems like something that would just get torn off.
