British SAS Desert Patrol Jeep "Part 1"
TheHun
Mar 18, 2011
66
67
Hey Guys,
This is a custom i have been working on for the past couple of months off and on, I'm getting better at remembering to take photos of the build as i go so bare with me......There will be 3 parts to this custom
A couple of years ago i picked up a busted up Solido die-cast jeep similar to this one, So its what i started with
After stripping it down, and finding the color i wanted to use, I cut away the grill and added the water cooling system
When i started on the inside, I had to remove the seats and customize them to where i could move them back as far as possible, I wanted to be sure that later on i could add custom figures, I also had to re position the steering wheel so it would be easy to get figures in and out, then i replace the rear deck and raise it up a little, After that i had to make 3 different gun mounts, one for a 50 Cal, one for a single Vickers, and one for the twin vickers.......on to the fun part....Detailing......
I did remove,customize and repaint the motor, Even tho there was no reason for it because once i add all the stowage you will not be able to raise the hood, Adding the detail and paint chips is a real pain, and time consuming, paint chips in 1/18 scale are really small .... on to part “ 2 “
You even painted the motor?!! Damn! Thanks for sharing the WIP pictures TH. This is an astonishing transformation.
funny how good it looked before you even did anything to it...and come to see later that it isn't sh!t compared what you ended up with...
